How to raise rear of typhon body?
avogev
  1. Typhon 6s
I've been looking for any body Mount options that Mount the same way as stock but no luck. Any suggestions? Just want to raise the rear
I actually am a bit of a fan of the proline body mount system....the one with a grub screw at the top and screw on caps. Takes a little linger to take the body on and off, but not much and provides better body protection to imo. I haven’t been on there website for a while to have a look but doubt they make them for Arrma
Because of the shock towers and the wing, the body on the Typhon doesn’t really take much abuse on flat surfaces. Obviously on uneven surfaces this may not apply.
Wondering why the OP needs more height? Is it for fans or larger ESC?
its for fans. but question is are there any type of extensions that can work with stock mounting points?
How much do you want to raise it? Cause.. I was lookin at my car.. And if your not afraid of drilling a couple of holes..its quite an easy job..
There are 4 screws holding the body mounts..
Forget about the bottom one.. Make the top one ur bottom one.. Drill a new top one around were my hex is..
Remount them in the new position.. And it will sit as high as shown here (right new/left stock)
So I used Kraton mounts the second tallest size, so now I have fan/battery clearance pins are a tight fit. The drilling of holes was good option but had no bits or drill. The side guards are from a Kraton also, They are used to hold 2 venom 3s 5000 50 side by side but height was issue before not no more. Using stock typhon side guards will not look like my height in pic.
Are the non pre-cut typhon bodies any taller? I’m looking at fixing this problem now with running dynamite reaction 3s.
