Notorious how to remove stuck sun gear
I just had this happen tonight. How did you sand the shaft?
Once it's out I just use some pretty aggressive sandpaper and hold the shaft with the paper and spin it with my other hand a bunch of times. I keep checking to see if it fits as I go that way I'm not going too crazy with it.
I suppose a better way would be a Dremel and grind down the bulged edges before you pull the shaft out
That is a sail jib, idk wut these guys are talking about.
It’s just an old nautical expression. If you like someone you say, “I like the cut of your jib.”
Or if you like someone’s “style”. The Tito’s comments are what I was getting at. 🤣
Absolutely correct, better than my explanation. I like your style. And Tito’s. 😊
