How are you liking the Mamba X? I almost ran that over the Max10 SCT.
I ran one in my original Granite and I still have one in my Senton. It's a great little ESC with lots of programming options and data logging. I also run it in my Rock Rey.
Tekno RC Shock Cap BushingsWhat springs are you using on your 81002/81003?
The springs that come with the fronts are ok, but in feel like the rear is way too firm and they are way too long. Are you guys putting limiters inside the shocks?
They look awesome with my Castle motor. Pretty close to the same color.
I used nitro fuel line pieces in the shock caps to mount them for now.
Barely any gap between the screw and ID or between the eyelet and shock tower?
Well done and thank you for the detailed post... I will hold fire on purchasing these for my Granite. I am about to order the non N models and will post pictures in 4-5 weeks upon arrival.I have seen conflicting information on these HSP shocks and so I want to share my findings so others may benefit. There are bits of info on these HSP shocks scattered overs numerous threads and so I am going to try and put as much as I can here in the correct post. I remember someone posting about these HSP shocks being a good fit for him but also that somehow they were diff specs (or dimensions) from one order to another order at some point in there.
But backing up for a bit. My Factory Front shocks both leaked in the first 2-3 runs. I took them both apart, inspected them and re-filled them with oil. The only thing I did differently (which I don’t know if it even helped at all) was I put some Associated Factory Team Green Slime on the o-rings inside the shock cartridge and am happy to report that I have had no issues since. Done.
In the meantime I did order some of the HSP Front 81003N & Rear 81002N alum shocks that everyone was talking about b/c I wanted an adjustable alum shock. They were inexpensive and so I figured I would give them a shot. $17.76 + $3 for shipping. They took (14) days to arrive. They appear to be good quality shocks as far as I can tell. I don’t know enough about springs and so I can’t comment IF they are a good option for the ARRMA Granite BLX that I own.
The first thing I noticed is the eye to eye dimension given in the Product Description does not match what I rec’d. Front 81003N - 105 mm (stated) but I measured as 111.9 mm with my calipers. Sure that is only 6.9 mm longer but it is different than stated. The same goes for the Product Description on the Rear 81002N - listed as 122 mm but I measured with the calipers as 130.15 mm. 8.15 mm longer. I have attached a bunch of pictures I took here and want to make sure ppl understand that while the camera angle may be misleading the given dimensions from my caliper readings are accurate.
I have seen people post about using the factory springs on these HSP shocks. How!?! I cannot put my factory springs on the shocks I received. See pictures. The ARRMA shock body is listed as 8mm (front) and 15mm (rear) where the body on these HSP shocks is listed as OD 23mm.
I mounted the Front shocks last night and the first thing I noticed is the springs touch the drive shaft. However I think I can make the Front HSP shocks work with maybe one minor modification (putting a spacer on the screw at the suspension arm in order to put some space in between the spring and the drive shaft) and also putting a spacer on the screw holding the shock cap to the shock tower in order to push the eye ‘forward’ towards the front bumper and away from the drive shaft. I would still need to test if the shocks will perform.
The good news is that I have been BASHING the hell outta my new Granite 4x4 BLX 3s with the factory shocks since I re-filled them with no issues. At some point however I def want an adjustable set of shocks. Maybe I can get these HSP’s to work…maybe not.
