bckyrdbshr
I just purchased a couple Infraction slider for my son and I. I'll be running the Firma 150 esc and Firma 2050kv motor in both truck on 4s. I'll also be converting from 14mm hex over to 17mm for running the bigger Hoons and GRP's. I'll also be using the 50 tooth steel spur. Both trucks will be used for street / lot racing and drifting, we wont be doing any kind of speed running as we don't have any good places where we are located. I need some good recommendations for the trucks according to the info I've gave about what they will be used for.
1. 50 tooth steel spur. What pinion would be good for maybe 45 - 50mph on 4s?
2. Diff fluid. What weight front and rear for the type driving we will be doing?
3. I will be replacing the Ring and pinion/input gears. Which would be stronger and quieter running HR Spiral cut gears or the CNC cut straight gears?
4. I will be replacing the stock shocks with Aluminum body threaded shocks. What brand of shocks do you recommend and what shock fluid weight front and rear.
Thanks in advance for your help, its highly appreciated!!
