- Limitless
- Nero
- Talion
Is there some formula or link I could use to calculate the horse power of my brushless motors?
If you know the amps and voltage that went through the motor you can calculate the power in watts. And watts times 0.00136 is the power in hp. Usually our brushless motors have an efficiency of around 85-90%. So the formula would be: volts * amps * efficiency_factor * 0.00136Is there some formula or link I could use to calculate the horse power of my brushless motors?
Yup 746, 1800 was my Bi Plane I just built.....sorry its still earlyYou would have to know your voltage and amperage to get watts. Once you know watts you can find the HP
I just round up and say 746 watts = 1 hp.
Then of course take total watts times 0.9 to take into account that 10% of power is lost to efficiency and heat.
If you do figure out how to find HP I'd like to know what the stock blx 6s power system makes.Is there some formula or link I could use to calculate the horse power of my brushless motors?
What about using the Max ESC drawing amperage?
How would you do that more accurately? You would have to load the motor some way other than running the vehicle and so the data might not be accurate? Maybe I've just got it all wrong?
And to expand on this further rolling road dynos often have issues with tires slipping. I can only imagine this would be worse with an RC car.For true 'rubber meets the road' power you have to use a dyno. Else you have to assume losses as per above.
Easy to calculate power the Lipo provides, everything else has mechanical losses, which can be estimated but not measured.
