Kraton Kraton 4s 2.5v motor support
You can move the support bearing over a few notches, see if that works!!
Isn't it molded into the chassis?
I just 3d printed this motor support https://www.thingiverse.com/thing:4982263/files
It doesn't fit since the motor sit further out with center diff. The motor support is right up against shaft bearing holder.
Anyone know if any other designs what might fit?
Take a photo of that 3D motor support near the bearing support.. and a ruler (in mm) of how much room you need.
Thanks for the replies. I ended up modifying the 3d model and got it to fit.
That does look like a good idea for motor support, personally I just rotated the heat sync/sink (whichever name it is but it don’t really matter) until it was against the chassis for support, but this looks like a great idea
Just make sure you use some double sided tape to stick it to the motor.
