KratonTheGreek
Greetings to the community!!
Was thinking changing my motor and leave my esc as it is.
Any suggestions?
Any suggestions?
The opposite is true. Lower voltage and a bigger motor will likely push more current through the system. It could be harder on the ESC.A friend told me nstead of playing on 4s cause it reaches to his limits with the stock esc. And play it on 3s with a bigger motor.
What is your opinion?
Thnx btw
Yes it should be fine as long as you leave stock gearing in place.Currently no problems at all. Can i play 4s with out worries on stock electronics?
Thnx bud. Much appreciated for your help.Yes it should be fine as long as you leave stock gearing in place.
