Kraton Kraton 6s 17mm Wheel Hex upgrades?
bobs1811
Any recommendations on upgraded 17mm hex options for K6S? (Using Method RC Terraform 1/8 tires)
The thread on the stock wheel hexes have been damaged due to this issue I had (https://www.arrmaforum.com/threads/wheel-not-coming-off.67260/) (managed to remove with heat and hammer) so considering to upgrade since they need replacing (well 2 of them but I don't mind replacing all 4)
Was considering M2C (also have 10mm, 15mm versions it seems)
https://m2cracing.net/shop/shop.php...-FOR-8MM-AXLES/p/478044804/category=136127923
https://m2cracing.net/shop/shop.php...-FOR-8MM-AXLES/p/570646476/category=136127923
https://m2cracing.net/shop/shop.php...-FOR-8MM-AXLES/p/571124814/category=136127923
Also looked at these
https://customrcupgrades.com/product/arrma-wheel-hexs-with-a-10mm-extension/
Not sure if the EXB versions are any different compared to stock v5 version.
M2c is always the way to go right now im converting my entire kraton 6s into a tank and i was like you between m2c and scorched but m2c is just the best in the market you should go with them
There are many options that will work, but the M2C you pictured will definitely handle it if the wallet allows. you can get the factory hexes from the FireTeam (thanks @KnowAir ) complete with new pins, and wheel nuts for like $9, and they should be fine, I just can’t stand that they still chamfer the edge that goes into the wheel hex side… I may be one of the few that it aggravates, but that’s just my personal preference. I honestly don’t have much opinion on MT wheels, as I don’t run anything but race grade 1/8 Truggy stuff, or factory Arrma at this time..
