Alien
I bought only the chassis with the body without electronics and wheels with the idea that I will install what I finally have at the moment without much cost, it is as in the photo.
I did a full diff service, replaced all bearings with new ones. I also installed new front steering blocks. To mount the esc, I used a plate from a 3D printer and rear covers. Kraton did not twist very much, so I added a washer for the servo saver spring. The wheels are Louise ST-MCROSS 3.8 Black MFT 1/2 Offset.
The motor is Hobbywing Ezrun 4274 2200kv cooled by two 35mm fans (cooling done quickly will change over time) Esc Hobbywing max6.
I am still waiting for the aluminum servo mount, this improvement is necessary in my opinion. If funds allow, I will change the motor to HW 4985 1650kv over time.
