ARRMA Adam
I have a 6s Kraton, not a blx. I went to drive it recently and it started acting funky. When I plug the batteries into the car, it only beeps 3 times instead of 6 like usual. The steering works perfect, but the ESC fan wont turn on. The throttle works, but when I set the throttle limit to 100%, it will go %100 for a couple seconds then drop down to %50 or lower, then the throttle dies completely. The batteries I use are 2x Spektrum 5000mah 50c Lipos. The remote I use is a Spektrum Dx2E. I tried recalibrating and re binding the car, but it still does the same thing. Maybe something with the batteries? Not sure. Help if you can. Thanks all
