I just tried to enable AVC correctly again after having it completely disabled - try this - reversed - rebound, calibrated, try that - still reversed - after 10 minutes I had a look at the manual to find out that my calibration sequence was reversed . sorted - now ready for tweaking I'd say - kept my settings for now before tweaking:
0: STR 0 - THR 0 - PRI 100 - this should keep AVC more less disabled, up to 100% override
1: STR 50 - THR 0 - PRI 100 - this should assist steering but not affect the power, up to 100% override
2: STR 50 - THR 50 - PRI 100 - steering assist and affecting power but up to 100% override
As I had it in front of me I just had a look on my rear shocks - similar not as bad yet but rubbing off - seems like the springs are off - if you try to bring it up or down a bit the portion it binds travels with it - I compressed/depressed them wiggle top and bottom of the shocks slightly to see if they aren't seated properly nope - something seems off here as well
I had exactly the same receiver was DOA but my LHS replaced it in store with another one - only had to wait a day before it arrived - they just ordered the same one and swapped them in store
My receiver was sent to me non working so I have a claim to make myself.
