Hi need some quick help please guys
If I turn the rear wheels on my K EXB 6S both turn the same direction plus they also turn the fronts the same
Reverse it and turn the front wheels then they turn in opposite directions
So that means it’s the center diff where the problem is doesn’t it?
I had the front diff apart recently and noticed that the lsd parts had worn through use
Put it back together,all was good after straightening one of the lsd plates out but then started to heat a slight click every so often
So I’m planning on replacing the internals on all diffs but am I correct in thinking all wheels turn when I spin the rear wheels that it’s the center that’s the problem or is it possibly the rear too
Thanks I’m advance for any help
And Merry Christmas
And Merry Christmas
