You are not thinking about this right. The front diff and rear diff have no bearing on how the power is split between the front and rear. This power split is done in the center diff.OK, so I was able to get the rear diff shimmed and all the rear diff and rear hub bearings swapped out. I did not reinstall the rear end, as I still have to do the center differential. I did make a mistake when I did the front end. I used 80K fluid, when I meant to use 100k. I was supposed to use the 80k on the rear and the thicker upfront, so I would not loose as much power thru the wildly spinning front wheels.
You did say in the OP that you were planning on using 500k in the enter diff - that will calm down the ballooning front tires a lot.
From the hudy set up guide - written for racers, but still applies to us bashers.
