Note: This feature currently requires accessing the site using the built-in Safari browser.
He's right. I put Kraton hubs and axles on my Fireteam. The black Fireteam hexs fit with no problem. It widens it up a little bit, but most importantly, I think it's more durable having more meat on the Hubs.As far as I can tell, you will need the front steering blocks and bearings; the front CVD axles; the rear axle carriers and bearings; and the rear stub axles.
I don't think you need anything but the hex adapters themselves? The red aluminum bits..What all is needed to add the kraton hubs to make the fireteam wider. I blew out a bearing on the front right hub and figured I should just widen it now.
I do wonder if there is any real difference between what Jim's or Eddie's is selling from factory Arrma.. not saying there is or isn't, but just that they ALL come out of China. Also, I doubt there's any difference from one Arrma 6s model to the next with regards to bearings used. They surely do get "bad batches" though. My brothers Talion exb blew both front inner hub bearings on day one!! That's bad!!As an alternative, you could replace the bearings with quality like Fast Eddy or Jim’s.
These are the same hubs as my Mojave and Talion. Those seemed to have come with better bearings from the factory
I agree many parts are likely the same. It’s all about factory assembly.I do wonder if there is any real difference between what Jim's or Eddie's is selling from factory Arrma.. not saying there is or isn't, but just that they ALL come out of China. Also, I doubt there's any difference from one Arrma 6s model to the next with regards to bearings used. They surely do get "bad batches" though. My brothers Talion exb blew both front inner hub bearings on day one!! That's bad!!
Agreed.No you need the axles front and rear.
I was looking around trying to see what all is different between kraton and FT. Looks like the actual cvd shaft is the same,but the axle is different. You may be able to use your FT cvds and just buy kraton stub axles. There has to be something else different though..because IIRC they both use the same plastic carrier/knuckle? Not sure..
