Leopard 4082 in nero
so i have done 4082 2000kv and 1600 on 8s ...the 2000 is now in my typhon its nuts but that motor can take the abuse i came back from a speed run and it was 310deg lol and smelled bad i took it apart and it had very little heat damage to the motor. i have not made a longer frame and am running tp4070cm
Lol damn, its not going to live very long at those temps. Monitoring temps in the high 100s is a waste but 310 degrees and the epoxy holding the magnets together begins to degrade and then melt lol. That's a hot motor haha
Ya prob not the best ideal lol I was playing with gearing in the Nero and was to low for that motor but now I'm running a tp4070cm so I'm good
I'm curious how you fit the TP motor in the nero. Ideally the nero would benefit from a 58mm diameter motor greatly.
Sweet dude! Good work! Are the driveshafts long enough or did you extend the rear? Can you stuff a 58mm can in there now? Wonder if its possible to mount the motor up top with a custom mount.
So u can mount on top but you have to run very big gears kinda a pain
