Looking for a plastic spur gear for my Kraton 6s
turn2burn
Tex Koder
2D , 3D Not a problem. I'll take that Challenge.
Dallas, TX (USA)
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Senton 3s
  6. Vendetta
Hey guys Im looking for a plastic spur gear for my kraton. I read this thread, https://www.arrmaforum.com/threads/plastic-spur.4231/
and it looks like I need this part TDR310586 team Durango. https://www.greathobbies.com/productinfo/?prod_id=TDR310586
I'd have to take off materiel for the output shaft and I don't know about the recess for the o ring on the inside of the spur.
Is there a more readily available plastic spur gear for the center diff of a kraton?
Why would you want a plastic spur?
As soon as you take a bad landing/tumble in a 6S rig it's going to bust some teeth's..
turn2burn
Mikeeeeeal
Northern Nevada
  1. Infraction
  2. Limitless
  3. Kraton 6s
I'm over here bitchin about my kids eating all the flamin hot Cheetos, you just threw things back into perspective for me.
Are you needing it to be off-road? My 4-tec has a sealed gearbox and I think it's quiet. Also what about the 4s line Kraton? That's sealed up too.
Tex Koder
Dallas, TX (USA)
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Senton 3s
  6. Vendetta
Yea thats what I was afraid of, I need to make it more quiet. I have tinnitus and hyperacusis which makes sounds painful.
Ah..
Okay. I understand.
I wanted to try a belt drive. Plastic wont hold up I know just thinking ideas.
Very interesting.
Belt drive would make it quiet, for sure.
Theres a closed gear box which looks interesting and would work in cooler parts of the year, Im up north.
https://www.aliexpress.us/item/3256...So&mp=1&gatewayAdapt=glo2usa&_randl_shipto=US
Holy smokes!!!
$85 for a transmission box!!!
How about you tip me some beer money and I'll CAD up a Custom 3D printed cover for you.
turn2burn
Yea its a bit much but the metal will contain a lot of the sound. I could make one out of carbon fiber super easy too. The not much room for a cover.
Belt drive is my best bet. Yea needs to be for off road. The 4s looks cool but Im committed, wish I had known that would have gone that way.
I don't know is that 4s really sealed like you can put lube in it? I might also loose my center diff all together if I went belt.
If its sealed it seems less stuff would enter the gears for wear. I might get that expensive housing.
Hector_Fisher
WA
  1. BigRock 4x4
  2. Granite
  3. Kraton EXB
I don't know if I suffer from either of those (I did work for 7 years in tire shop though and it royally screwed my hearing up) but I whole-heartedly agree. For me, hearing the kraton roll makes me ears start thumping and ringing and gives me a massive headache. It's not the volume, it's something else. Not really when on throttle, only when it's rolling and does that awful high pitched ringing from the gear clash. Whatever it is, I feel you 100%.
What about instead of a cover, a "shield" to deflect sound in a different direction? Like down? Perhaps with the addition of some thick plastic to assist absorbing sound waves?
The transmission box does look like a solid option to help contain the sound.
TheBadazz
RCHolic
Chi
  1. 4x4-Mega
  2. BigRock 4x4
  3. Felony
  4. Fireteam
  5. Granite
  6. Infraction
  7. Limitless
  8. Kraton 8S
  9. Kraton 6s
  10. Mojave EXB
  11. Notorious
  12. Outcast 4s
  13. Outcast 6s
  14. Outcast 8s
  15. Senton 6s
  16. Senton 3s
  17. Senton Mega
  18. Talion
  19. Typhon 3s
  20. Typhon 6s
  21. Vendetta
  22. Vorteks
  23. Infraction 4x4
Just asking. Would it help to use ear plugs or maybe sound suppression headset like they use at gun ranges?
dure16
Illinois
  1. Fireteam
  2. Granite
  3. Infraction
  4. Limitless
  5. Kraton EXB
  6. Outcast 8s
  7. Typhon 3s
  8. Typhon TLR
I actually designed and 3D printed one recently. I made the gear teeth much wider to take advantage of the pinion overlap.
I printed in basic nylon and it worked fine for a little while. Almost a whole battery pack of hard driving in a Typhon 6S (running 4S). It eventually failed because the small cylinder broke off from the main part of the spur. There’s just not much room to bulk up the material there.
I could spend some more time on the design though (this was v1). It also might hold up better with stronger filament - perhaps something like carbon fiber nylon.
Do you have access to a 3D printer?
Moirae
Beauty & Beast
Rig of the Month Winner
  1. Felony
  2. Fireteam
  3. Infraction
  4. Limitless
  5. Kraton 8S
  6. Kraton EXB
  7. Kraton 4s
  8. Mojave EXB
  9. Notorious
  10. Outcast 8s
  11. Outcast EXB
  12. Talion EXB
  13. Typhon 3s
  14. Typhon 6s
  15. Typhon TLR
I don't know why but this is so cool to me.
Adiabatic
Doing it myself and doing myself in
  2. Vorteks
#MeToo. I suggest wearing musician earplugs while bashing, as they have a flatter attenuation of sounds across the audible frequency range, which is more like turning down the volume without muffling the higher frequencies we need to hear ambient noise and speech, as regular workplace earplugs tend to do.
They're great for concerts, loud restaurants, etc. as well.
bukshypro
London, UK
  1. BigRock 4x4
  2. Granite
  3. Kraton 4s
  4. Outcast 4s
  5. Typhon 3s
  6. Vendetta
  7. Vorteks
I watched a video where they shown some materials that they used for 3d printing holding up 3-400lbs of weight, I wonder if gears made of those would hold up better than default Karna composite?
morrjr71
The Old Guy
Military Veteran
Mechanicsville, MD
  2. Typhon 3s
  3. Infraction 4x4
I put a PPS motor mount in my Kraton 6s. The PPS mount has micro gear mesh adjustment, and when the mesh is adjusted properly the sound of the spur and pinion gears is greatly reduced. The PPS mount isn't cheap, but in your case it might be worth it.
https://practicalproto.com/products/grublock-motor-mount-for-arrma-6s-blx-platform
I have the full PPS mount system with the diff support, top plate, and roll bar mount. The wear on the spur and pinion gears occurred before I put in the PPS mount.
StephenSchandelmayer
Florida
  1. Limitless
  3. Kraton 4s
  4. Outcast 8s
  5. Typhon 6s
Earplugs probably are just the way to go but if you decide to get the closed in motor mount you should get this one from vitavon. Great quality parts and it's actually more closed in than that other one is. Comes in red or silver. Also same price 👍🏼
https://www.ebay.com/itm/2844661036...JylWtYAS6u&var=&widget_ver=artemis&media=COPY
Looking at the other one again I guess it would close up once you actually set gear mesh. But still I vote vitavon
RedOctobyr
Lowell area, MA
I have a tinnitus situation as well, though it's not as bad as what you're experiencing. I'm sorry you have to deal with that.
I wear hearing protection for whatever I can, if it's anything approaching loud. Musician's earplugs for anything like a concert (and we're not talking a loud rock concert). Regular earplugs (or noise cancelling earbuds) and 3M earmuffs, together, for cutting the grass, etc. These seemed to be the most noise reduction I could find:
3M PELTOR X5A Over-the-Head Ear Muffs https://a.co/d/hSyHZsq
I don't care if they look odd while mowing :) Thankfully my electric truck (just bought) hasn't been a problem. But if I still had my nitro, I'd probably wear something.
Agreed that a belt drive would probably be quietest. Not trivial, though, unfortunately. There were belt drive 4WD touring cars, back in the day, maybe something exists that could be a starting point?
Does anyone sell angled gears, or some other style that's quieter than straight-cut? Of course, you'd still have the front & rear differentials to deal with. I wonder if trying to kind of pack sound insulation around the the different gear sets could help muffle them?
Heck, even adding something to the body, so it helps deaden the sound, rather than acting as a big sounding board? Silly, but imagine wrapping the body with part of a towel (the outside is probably simpler), just as a test. I'll bet that could help.
