Logan's_Rcs
Really considering purchasing a 1350kv TP 4060 and comparing it to my 1520 1650kv in the MT410. Both motors are approximately 4092 size, and I'm curious as to whether less RPM makes the motor more efficient when geared for the same speed. I calculated out the 1350kv's losses compared to other 4060s, and it is actually one of the most efficient motors in the 4060 lineup, even on 6s. My thought is this: if the Iron/copper losses (waste wattage turned into heat) is about the same as the other 4060s (1650kv, 1730kv, 1950kv etc) on 6s, then wouldn't the lower rpm geared for the same speed run cooler? I would imagine that higher rpm motors draw more amps just to spin up. So while having the same amount of losses and dropping the rpm by approximately 10k, then gearing up for the same speed, I would imagine it would make the motor run cooler.
Has anybody experimented with this, two of the same motor but different kv's geared for the same speed?
Thanks!
Thanks!
