Kraton M2C warranty?
Jluther@becoinc
  2. Talion
I was just wondering if M2C had any type of replacement guarantees on the axle pins in the 6s axles. Seems like I heard at one time they had changed material because of excessive wear. They don’t bend but the pins wear quicker than stock
There's a tool kit from Meugan and pins,a bag on ten,you can replace it in a couple min.
Thanks ! I’ll try to find it. I had no idea they were replaceable. I’m trying to get the bad ones out now. Part number?
As far as I know, they have a 50% replacement policy.
Buy if you feel like this is a defect in workmanship/quality and the pins are wearing faster than normal under "acceptable" running conditions then I'd definitely hit them up and see what they can do, especially if you think they changed pin materials.
I'm assuming they are the same size,they should be, I've used them in different manufacturers shafts,I have to replace them every 2 to 4 runs because of the power I'm putting out in a speed run
C0270 does driveshafts and inner axle shaft, C0271 does outer axle shaft
Use green or blue loctite when you press them back in... you can use a drill bit shank and small vise with something on one side of the joint to let the pin pass thru while supporting the joint, or buy the kit, but it's kind of pricey imo
Here's what the tool looks like
Thanks for sharing your experience. Nothing is perfect even m2c. I would see what they say myself as you just never know until you
Oh yea the parts survived crashes I know would have buckled the stock shafts. I’ve bent a ton of stock shafts. I hit a tree one time and busted both front diff out drive cups but the axles were straight as new. I sent an email to M2C and got an auto response that said they’d replace anything once for 50% off. I’m going to give them a call on Monday to see how to get it done. Already had a backup set lol 😆
