I'm just wondering what every one is doing for a maintenance schedule, such as how many packs run before complete tear down. How long bearings should last between replacements and so on
Everyone is completely different. These are not scale cars that get an oil change at preset intervals. Different driving dictates. We all drive differently and in different climates and terrain. There is no definitive answer in my opinion. Doing this for 30+ years with many diff brand rigs.
From my exp. my 6S rigs get about 10-15 lipo packs of use before a bearing or 2 fail. I rebuilt my Kraton twice and averaged approx. 10-15 packs in it. When bearings start to fail. Get an upgrade set of sealed bearings and tear it down. Or just replace what bearings or parts failed here and there. But once more than one bearing fails, its safe to say the others are on their way out. Everyone has a diff. philosophy that works for them. The key is to check the rig over after every run. You will see wear and tear develop and you just keep tabs on it. Check for loose screws even when new out of the box. Check that the diffs and shocks are not leaking or the shafts bent etc.
Inspecting all closely is important. If you keep driving and driving and never check things over until it is too late you will need to rebuild more often, you will get burned for sure out in the field at some point. Others may chime in here. Good luck
Hey! How do you know when a bearing is done?I'm just wondering what every one is doing for a maintenance schedule, such as how many packs run before complete tear down. How long bearings should last between replacements and so on
