- Florida
- BigRock 4x4
- Fireteam
- Infraction
- Kraton 8S
- Kraton 6s
- Mojave
- Senton 3s
- Typhon 3s
Hey guys, so I started hearing a clicking coming from the rear end. Figured I might need to add a shim to the rear diff, so I opened it up for maintenance. Upon opening I found that it was caked full of crud and had absolutely no grease in there. I bought this as a second hand roller fwiw. I see there's one shim installed already, but before I add the second the shim I want to get things all cleaned up & greased. If a second shim and grease don't fix the issue, then im just going to put a whole new diff unit in this sucker. What grease do you guys recommend putting in the diff case?? Thanks.
