Kraton Mamba Monster X 8s Fan!! Gahhh!!!!
Didn't Know Where To Post This So Why Not Here.
Can Someone Please Direct Me To A Real Fan That Will Hold Up For The Monster X 8s!!! Preferrably Same Dimensions If Possible!!!One Jump And This Fan Chucked Two Blades :(((
Thanks In Advance!!!!!
Stock ones are garbage, broke one in my Infraction.
I got a team brood one, only have one run with it in a infraction so can’t speak for durability, it blows a lot though. Link :
https://www.amainhobbies.com/team-b...-cooling-fan-red-bro-tbr-ventusxlred/p1400589
Rocket fans. I run one on the MMX8S. I wired it from the receiver, so it's always on.
Thanks For The Links! , Okay I Gotta Be Honest, I'm Doing Backflips!!! I need a Backflip Capable fan!!! hahaha
Why does Castle do thisssssssss!!!!!!!
The Castle fans are 10-13 bucks shipped and are not worth 50cents!!!! Hello Castle!!!!!!!!
Castle definitely need to work on the fan and it’s mounting assembly. If you mount an aluminum fan on the top of that thin plastic it will tear the whole top off the esc. Be sure to tie wrap it down like Sircrashalot did. I had two of them completely tear off the top of the esc. Maybe some day Castle will make that shroud out of aluminum. If anyone finds an aftermarket cover let us on the forum know about it. I’m a BACK FLIPPER TOO!
ended up getting both the rocket and the team brood, both seem like the exact same thing and sound the exact same but weigh a gram different between the two, using the Team brood and saving the Rocket for backup, both seem the same for smoothness, thanks again
