Where did you see or hear this?
Merely using any NON Sensored motor without sensor leads should always work. Plug and play. No ESC settings need to be made. It just works. You can even run the comboo motor in Non sensored mode by not connecting thes ensor leads.
If it doesn't work , perhaps the Kv value and gearing of the Non sensored motor in question was at fault. Or simply was a bad Non sensored motor out the gate. More probable. Not the Max 5 G2. I never heard of anything to the contrary.
Again, where did you see this?
I am skeptical of RC urban Myths professed by one person and it propogates BS all over the interweb.
Yeah same here, I have max5 g2 and castle 2028 800kv running 12s and my brother has max5 g2 800kv combo and they both run fine sensored. I was just curious about the non sensored part.I have 2 non sensored max 5 g2 rigs on 12s. Both are paired with a TP motor and both have zero delayed power problems. This is my first time seeing someone complain about it but I have seen people complaining about a power delay while using the full max 5 g2 combo. Aldo on youtube for example has been complaining about it and I noticed something similar on my max 8 g2 combo but it's weird because I don't have that problem in my 12s xrt using the same 800kv combo aldo has.
In fact, I test drove my 12s kraton last night with max 5 g2 + tp 5860 motor and it felt so smooth I was mind blown. If someone told me it was sensored I would have believed them.
+1It's the way the motor wires are wound on the inside of the motor. I don't know the exact differences but I know Y winds are easier to make and typically run cooler and less amps. TP motors state which wind each motor is on the motor page.
https://www.tppowerusa.com/index.php?route=product/product&path=20_71_146&product_id=483
I have this coming in the mail for my kraton 8s right now and it's the same motor @GNT1 was talking about. I got the sensored version in a 12s on road rig =D
Yea I've started to just run 0 timing on basically everything unless I know for sure it's a y wind.+1
Most RTR and cheaper motors are Y Wound. When you get into the expensive Exotic motors you will find some are D wound. Usually Hand wound. You generally don't want to add any Motor timing with D wound motors. Some food for thought. Always drop Motor timing down, when you have issues. First thing to check. No matter the type of winding. Evaluate from there.
So for a 12s set up D wind would work fine leaving timing at 0?+1
the 745 or the 850! I'd probably pick the 745 though.What would be a good D wind 12 capable TP motor? And what's the KV I should look for?I mainly run my kraton on open grass fields.
And looking on TP motor specs it seems like 12s set up like higher voltage capable motors so 745kv D wind would be the choice?
Hopefully max5 g2 will run it fine cuz I ordered the 745kvI run the 745 in my EXB. I run it off the max4. That motor is a beast!
Yeah this would probably would be my next motor after castle goes.the 745 or the 850! I'd probably pick the 745 though.
Did you make motor wire extensions yourself or bought it from some where? (Do you have a link if you bought it)
Radiocontrolpower.com has extensionYeah this would probably would be my next motor after castle goes.
lol thats crazy, wonder how I have 2 rigs working perfectly fine. One of them is a first batch max 5 g2 too.View attachment 325185
Here is another comment that I've found
