Kraton Max6 4985 combo in a Nero, need some help with gearing
Denmark
  1. Infraction
  2. Limitless
  3. Kraton EXB
Hello there great people 😀
My friend has a Arrma Nero big rock with pro-line 3.8 belted wheels
I have bought a new hobbywing max6 1650kv combo for it, but what gearing should I go with for bashing
Is 20t the way, maybe just a 18t. I run a 21 i my Kraton Exb with same motor
Normal it's got a 15t and 17t for speed and they spur is 46 if i remember right
There is 2 3s 7000 100c battery for it
The nero is a compact car, it will be a very tight fit to fix a max6. I don't think you could fit bigger than a 40mm in dia. can in the nero without modding the car heavily. The gearing on the nero is also significantly different. I would say probably 3 teeth more than you would run in the KEXB, but at the same time the nero is a heavier car and since it is harder to get parts for it I wouldn't recommend anything above the speed gear.
