Limittless
- no where😗
- Infraction
- Limitless
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Mojave
- Mojave EXB
- Talion
- Typhon 3s
- Typhon 6s
- Typhon TLR
- Typhon Mega
- Vendetta
- Infraction 4x4
update?Clearly it all leads to a GT build. But my plan is to take the open wheel config as far (fast) as I can....and only when I can no longer get faster switch to GT. I already have all the parts as planned...including the chassis extensions / wide chassis as well / and a gt body...
But I want to try this two stage approach, as my goal is to test all limits and understand exactly what has an impact and what doesn't matter so much...so I can only do that in slow small steps unfortunately.
The battery box looks more complicated indeed. But with the esc, I had to design it from scratch (the battery box is from thingyverse and just resized a bit).
The design from scratch however was not the main part....rather the material. Initially I used PLA and a coat of glue. It kept coming apart when I did drilling and cutting. Then I spoke to Tomas (from MGM) and he suggested where to drill the holes.
Then I decided I'm gonna go with PET-G. I had to learn how to print PET-G Then I had to figure out the wires and stuff...and what's the best place for them to come out...
Point is....when I say two months...I don't mean it litteraly .... I mean....from when I designed the box and then tweaked the measurements to fit it perfectly (which took some measuring and many prints) then....switching materials....etc....it was quite a slow process. This considering that I work and have kids....which means ... I can't do this when I want to
Have you got any suggestions as to my question about the servo?
