jedijed
- Kraton 6s
- Kraton 4s
- Mojave
- Typhon 6s
My motor bearing went out yesterday, it looks like it got some contamination, aka dirt inside the bearings. The rotor itself seems ok, I ordered some Jim's bearings, but I am worried that I might not put it together correctly.
-Any tips on rebuilding?
What would you do?
-File a claim with Arrma for a motor replacement or rebuild?
-Try to fix it myself?
-Do one of the above and buy a new motor
-Buy another stock motor?
- Buy an aftermarket motor? -will aftermarket motors work with the stock ESC? It looks like the stock ESC is 4mm plugs and most aftermarket motors are 6.5mm plugs.
-Just a motor or ESC and Motor Combo? I would like something that runs cooler, could be not as powerful, since this car is primarily run on a friend's very large track and full power on 6s is unnecessary. What motor and ESC do you recommend for running cooler and having the same or less power than stock.
What would you do?
