- Montréal, QC, Canada
- Felony
- Notorious
- Typhon 6s
- Vendetta
- Vorteks
Hi all,
Here is my pride and joy, the ultimate Baja Raptor Rey V2 1/10 3S;
I worked on this RC for more than 20 hours and more or less $400 of parts were installed!
I didn't remove the body and cage for the picture since it's a chore to do it. I'll update the pictures next time I wrench on it.
Update 2024-03-12:
I have installed new CNC parts, I had to tap the Losi servo arm from 0.6 to 0.5 pitch. Check the new photos below and the part list.
Here is the parts list with links for reference, most link are Canadian websites but you can change country in the settings;
-Losi aluminum front upper tower shock mount LOS334005 ( https://www.amazon.ca/dp/B01MXXOLA2 )
-Vitavon CNC aluminum rear axle and differential case ( https://www.ebay.ca/itm/284849574287 )
-Vitavon CNC aluminum Center Transmission housing ( https://www.ebay.ca/itm/283443921977 )
-RCAW center beefier driveshaft ( https://www.aliexpress.com/item/1005004573626116.html )
-EPTNNASO Harden Steel Rear Center Driveshaft CVD ( https://www.amazon.ca/gp/product/B07BF5L67P )
-RCAWD rear beefier axle shafts ( https://www.aliexpress.com/item/1005004573903073.html )
-Hot Racing front differential CNC aluminum bulkhead LRR12FL01 ( https://www.ebay.ca/itm/363865862294 )
-RCAWD aluminum trailing arms link ( https://www.aliexpress.com/item/1005004573989382.html )
-Rocket RC motor dual fan and heatsink ( https://www.aliexpress.com/item/1005004796082523.html )
-Spektrum HV High Torque servo S6250 ( https://www.zonehobbies.net/product...gh-torque-metal-gear-waterproof-surface-servo )
-RCAWD aluminum servo mount ( https://www.aliexpress.com/item/1005004560371886.html )
-Losi CNC aluminum servo horn ( https://www.amazon.ca/gp/product/B01NH9Y63P )
-RCAWD aluminum steering kit ( https://www.aliexpress.com/item/1005004836543539.html )
-RPM Front Upper & Lower A-arms RPM73882 ( https://www.ebay.ca/itm/391977731233 )
-GPM Losi etched full under carriage metal skid plate ( similar look https://www.aliexpress.com/item/1005005821772353.html )
-GPM steel rear upper links ( https://www.ebay.ca/itm/225185681177?var=524109868831 )
-TRINOOD Aluminum Rear Upper & Lower link and arms mount ( https://www.aliexpress.com/item/1005004437968593.html )
-RCAWD Two additional 1/8 suspension damper in the rear. ( https://www.ebay.ca/itm/182383445717?var=484951057956 )
-3D Printed Roof Slides armor (not shown in picture) ( https://www.ebay.ca/itm/295563927363?var=593631315312 )
-Powerhobby Defender 2.2 belted Tires ( https://www.ebay.ca/itm/393606092466 )
-New Enron Ken Block mud flaps ( https://www.aliexpress.com/item/1005004015014848.html )
Update 2024-03-12 parts:
-Vitavon Front steering knuckles (https://www.ebay.ca/itm/284793065311)
-Vitavon Toe Link (https://www.ebay.ca/itm/283425542440)
-Vitavon Steering drag link (https://www.ebay.ca/itm/284602267451)
-Vitavon Steering Bell Crank
I have change the fluids for the diffs (TLR 1mill rear, TLR 500k mid and TLR 100k front) and TLR 37.5 oil shocks all around.
The fake disk brakes have been removed and I've installed three M6x9x0.1mm thick shims between the hub and wheels on all four corner.
As for the Spektrum ESC Programmer plug, I just installed a ESC fan splitter wire and just plug to program it.
I have removed the front sway bar, there's lot less rollovers.
If you have questions, don't hesitate to leave a reply.
Cheers
Update 2024-03-12:
Cheers
