Now in stock ready to ship.
Sorry for the delay.
http://www.fasteddybearings.com/arrma-nero-sealed-bearing-kit/
If you still have the ORIGINAL as well as the ones we sent a measurement on both will be helpful.Thank you, you guys are awesome. It is the inner hub bearing that is causing the problem.
12X18X4. the inner diameter is slightly off causing the shaft to be able to wiggle on the inside of the hub. I will measure it precisely at work in the morning.
Would you happen to have a caliper to take a few measurements of both bearings?Sorry for the bad photos. the stock cannot be angled while on the shaft. your bearing can be tilted slightly while pushed all the way back.
