Kraton New Savox servo, what's needed for install ?
toyopl
Fried original servo on my Kraton on 6th run :)
Picking up Savox SW2290SGBE servo as a replacement.
I searched previous threads and figured out you need Hot Racing 25T Servo Arm HRAAON24M02 to go along with savox for install.
Is there anything else needed to complete the servo change ?
I'm new to R/C, 6 runs in and servo fried :)
Welcome
I am not familiar with that servo but if your RC already has a 25T horn you should be good or need to get one. Outside of that, you do see some horns linkage to the bellhousing you might need a few shims to level the arm to close to a 180deg straight line. Might not each servo height is different.
Spektrum stuff uses 23T so the original horn won't work. FWIW your new servo will come with an assortment of horns that'll get you going but something like the HR aluminum horn is definitely recommended.
