Hi all. Im settling on finding a used outcast or notorious. Can anyone tell me what changes were made to v1,v2,v3? Also the year/ date they were made or sold? Thanks! Also how often do used ones show up on this site? Thanks!
I'm not sure about all the dates. Outcast has 3 models, the Notorious has 2. A V2 Outcast is the same and a V1 Notorious (except for the body). The big differences from V2 to V3 Outast and V1 to V2 Notorious are:Hi all. Im settling on finding a used outcast or notorious. Can anyone tell me what changes were made to v1,v2,v3? Also the year/ date they were made or sold? Thanks! Also how often do used ones show up on this site? Thanks!
Roughly.Ah so if i found two(one old and one new version) priced $100 different I'd still be better off getting the newer one as all of the upgrades would add up to be about the same?
You need to factor in the radio. You *have* to replace the new radio. The older version with the Tactic does not need to be replaced. The only upgrade you really need is the motor mount. The new servo saver blows. You can use e clips to keep the balls from popping out of the ends. The new pillow ball caps are not that great. Personally I'd go for the older version and use the $100 for the new motor mount and some metal chassis braces.Ah so if i found two(one old and one new version) priced $100 different I'd still be better off getting the newer one as all of the upgrades would add up to be about the same?
Roughly.
Some prefer the v2 servo saver as while it loosens on you if you don't locktite the bejebus out of it, it's also relatively easy to adjust.
The captured rod ends are nice as would be the PB caps with an o-ring.
I have the v2 outcast with many much upgrades. I did get the capture rod ends and I do like that. I also replaced the stock plastic chassis braces with alloy, M2C chassis and a fist full of other stuff. Most of which I would have done be it a v1, v2 or v3. The only thing I wouldn't have upgraded if it was a v3 was the ball ends.
I think the original v1 had a different battery box/tray. The v2+ all have the same one. I think @bicketybam posted a how to on how to upgrade that as well with flange nut/inserts, which I also did.
Are there any replacement steering servo units that work better on the V2?You need to factor in the radio. You *have* to replace the new radio. The older version with the Tactic does not need to be replaced. The only upgrade you really need is the motor mount. The new servo saver blows. You can use e clips to keep the balls from popping out of the ends. The new pillow ball caps are not that great. Personally I'd go for the older version and use the $100 for the new motor mount and some metal chassis braces.
This is all good info? I planned on getting the M2C chassis as i plan to send it.
Hot racing makes a clamp style servo saver that locks downDs3225 sg the blue coreless one works great and only 30$
I have that one. While it works, it's a bit of a pain as you have to take the side guard off to tighten/loosen the screw. I guess that's better than welding the nut on with red loctite... blue gel loctite let go after a while. Didn't try plumbers tape though.Hot racing makes a clamp style servo saver that locks down
That is not the latest model oh, that is why it has no Center brace. As for what it's worth, it looks all stock to me. And it's used. Personally I would pay no more than 250 bucks.Hey guys what version is this and what would you pay? Grey body but no red center brace. I thought the v4 comes with a center brace? Comes with a 50c batt and passport ultra p2 charger.
$250 for all? Truck, batt and charger? Also is this the v1?That is not the latest model oh, that is why it has no Center brace. As for what it's worth, it looks all stock to me. And it's used. Personally I would pay no more than 250 bucks.
No that's a V2.$250 for all? Truck, batt and charger? Also is this the v1?
Would you guys say this one is heavily used and would concider replacement pinion gear any electrical parts ? The guy says he bought this last April. Idk though looks older.Trust me when I tell you this you do not want a V1 Outcast, the easiest way to tell if it is a V1 is the lack of shock cap protectors and the small rectangular rx box.
No that's a V2.
It honestly doesn't look too bad just really really dirty and I don't see a bunch of rusty screw heads so that is a good sign.Would you guys say this one is heavily used and would concider replacement pinion gear any electrical parts ? The guy says he bought this last April. Idk though looks older.
Agreed. And to top that off he's askin $500 usd. Idk if the battery was properly maintained.It honestly doesn't look too bad just really really dirty and I don't see a bunch of rusty screw heads so that is a good sign.
It really annoys me when people try to sell their cars and don't even bother to clean them before they sell them. That truck would look a lot better if the dude even bothered to clean it.
$500 is too much, maybe if it was a V3. Including batteries and a charger I would not pay any more than $350.00 but start lower and work your way up. 1 it's all stock, 2 it's an older version and 3 it's dirty as all hell.Agreed. And to top that off he's askin $500 usd. Idk if the battery was properly maintained.
Just a bit of soap and water would help big time.
To be honest most of the time buying used rtrs is a crap shoot as you never know how the previous owner treated the vehicles and you will likely end up spending more money in the long run vs buying a new one. I've bought 6 used rcs over the years and all but 1 needed a complete rebuild, the 1 just needed a body mount thankfully I got them at such a steal i was able to dump money into them.
