- San Antonio TX
- Felony
- Granite
- Infraction
- Kraton 8S
- Mojave EXB
- Outcast 8s
- Typhon 6s
Someone did 102 mph with a K8S and this ESC. They did some trickery with batteries though and used some special tires and other stuff, but that's still very impressive for a 30+ pound truggie. I'm not sure what motor the used though. It was innovation RC I believe. I'm not looking for insane speed. I'm just looking for more torque for my Outcast 8s than the stock system ?Very nice! I just ordered the same combo with 2 39t limitless spools for my k8s. Pps slider slso
I believe with castle it’s backwards and you want punch at 0% Otherwise your limiting it...I have punch at 100%
Really? I'll have to do that then. And my pinion was completely loose too. Thanks.I believe with castle it’s backwards and you want punch at 0% Otherwise your limiting it...
I think they call it “punch control” which is confusing, but from my understanding the higher the % the more it limits it.Really? I'll have to do that then. And my pinion was completely loose too. Thanks.
Yup it's called "punch control". Damn. Ok. I'll go for zero tomorrow. It will probably do a standing backflip. Yeah it was acting like it was on punch setting 1 on the Hobbywing stuff ?I think they call it “punch control” which is confusing, but from my understanding the higher the % the more it limits it.
Let’s hope so! ?It will probably d a standing backflip ?
I see a benefit of not having punch set so high. I think that extends your battery life. I got about 20+ minutes with punch control at 100%. Hehe. And that's with my cheap 6500mAh 60C 4s youandme batteries. I'll try with punch control at 50% and see what happens with the battery life but I believe that extra boost at the beginning really takes a toll on the battery life. That's what some people say and I'm almost agreeing with that at this moment.Let’s hope so! ?
Having my punch set to max power killed my 9700mah 120c SMC batteries unbelievably quick. The batteries were pretty warm afterwards. I was also punching it everywhere, but that's besides the point lol. I'm gonna look into some 160C batteries to really make it moveI see a benefit of not having punch set so high. I think that extends your battery life. I got about 20+ minutes with punch control at 100%. Hehe. And that's with my cheap 6500mAh 60C 4s youandme batteries. I'll try with punch control at 50% and see what happens with the battery life but I believe that extra boost at the beginning really takes a toll on the battery life. That's what some people say and I'm almost agreeing with that at this moment.
I turn my punch down to 0 on my max5 and 850kv TP, any more just destroys the drivetrain slowly and I don't notice much of a diff, these motors are incredibly powerfull.I see a benefit of not having punch set so high. I think that extends your battery life. I got about 20+ minutes with punch control at 100%. Hehe. And that's with my cheap 6500mAh 60C 4s youandme batteries. I'll try with punch control at 50% and see what happens with the battery life but I believe that extra boost at the beginning really takes a toll on the battery life. That's what some people say and I'm almost agreeing with that at this moment.
Cool. I tried punch control at 50%and now I can do endless wheelies and put the O8S on its roof. I only ran for 7 minutes though. I'll see what my battery percentage is left when I connect them to my charger. I might go to punch setting 1 on my xmaxx trucks with the max 5 and 1100kv since I'm beginning to bend driveshafts after only one run ?.I turn my punch down to 0 on my max5 and 850kv TP, any more just destroys the drivetrain slowly and I don't notice much of a diff, these motors are incredibly powerfull.
Hehe. How long did they last? I know before I the upgrade I would get like 20+ minutes with the stock electronics and 21t pinion on the O8S with 9400 75C smc batteries.Having my punch set to max power killed my 9700mah 120c SMC batteries unbelievably quick. The batteries were pretty warm afterwards. I was also punching it everywhere, but that's besides the point lol. I'm gonna look into some 160C batteries to really make it move
Probably 25 minutes to LVC, whereas on stock electronics with these batteries, you get way longer run timeHehe. How long did they last? I know before I the upgrade I would get like 20+ minutes with the stock electronics and 21t pinion on the O8S with 9400 75C smc batteries.
That's not too bad. I thought you were going to say 10 minutes ?Probably 25 minutes to LVC, whereas on stock electronics with these batteries, you get way longer run time
Update. Since this was an open box purchase, I'm missing the correct connector that goes straight into the ESC. I just watched a video, so I'm trying to connect the sensor wire directly to the ESC, which will never work! OK I'm going to call Amain and complain about that because they didn't specify that was missing. I was also missing the 8 guage wire that is used for a jumper when you solder. Damn.
