So this is how it goes. Grab yourself a set of Traxxas rustler drive shafts,like 12 bucks and maybe from the same place get 4 5x11x4 bearings. Then this is the time you have to decide if you want to take a chance or spend the 20 bucks to get four sets of outdrives.Think
Ok so you also going to need 4 grub screws 3m, but longer than a pinion grub sooo cuz im cheap I used a 20% coupon from HF and got a box of grub scerws 6$,your only gonna use the smallest ones but if you have minibikes/gokarts the rest will be handy to have.Think
Now you have to ruin things. What you have to do is drill the axle carrier out to 5mm or 7/16 be careful and keep it strait,now chase the rear of the carrier about 1/16th with a 1/2 drill because the traxxas shaft has to be countersunk JUST A BIT so you can put the hex pin in the axle and INTO the hex. No Pics sorry,I wasnt in the mood nore am I youtuber generation.Think
The four grub scews go into the 2 traxxas driveshaft yolks(mine were just a little bit below flush(traxxas uses a pin and were clamping) when tight.Take your time on all of this!!! I dismantled the suspension and put the inner(male) on first. Now ill tell you I cut the male shaft about 1/2 inch shorter and filed and beveled it to fit and slide free.It might of been fine stock.Think
Now assemble and take your time.Me, I put the rear bearing one the axle and seated it,then front bearing and checked to make sure the hex pin fit ALL the way into the hex without binding,if it binds coubtersink the back of the carrier JUST A BIT more. Fiddle and make it work,this is just a rig.Think
I said but? Because for whatever reason with 6 arrrma cells on the test drive the steering servo just started spinning , This was however after about 20 mins or so of my grandson flying around the backyard. Its flat but he has a relentless trigger finger forward ,backward wheelies flips up his legs, the drive was fine BUT the servo failed or the esc,Im about over this thing. I shared my fix got any ides for mine,my truck has been a dud since day one. Batteries,Esc,outdrives I guess the servo was last in line. About me,been saving paper route money for a year,building and fixing these since 85,I just got a bigger route now,lol. Again sorry no pics. on the marrow ill take a couple
