- Mississauga
- 4x4-Mega
- BigRock 4x4
- Granite
- Typhon 3s
That’s called the slipper clutch assembly.What is this spur gear and clutch setup? The clutch seems seized but really I have no idea what I am looking at.
*rear*Okay. Now that I have it apart I see how it works. The spur gear has like way too low teeth for me to use and wrong pitch I think. But as a clutch it's way better than whatever spring thingy came with my car. I have to cut the screw that tightens it because it's too long and it too big diameter to fit with whatever input gear goes into my read differential.
Here are some clearer pictures. Do you have any clue the pitch for this gear? I am hoping it is 32P and is just a BLX part then I can find a 32P pinion that fits on the 3mm shaft of the 12T brushed motor.
That appears to be the 48p spur from the Mega line. The BLX line uses a Mod 0.8 (32p) gear.Here are some clearer pictures. Do you have any clue the pitch for this gear? I am hoping it is 32P and is just a BLX part then I can find a 32P pinion that fits on the 3mm shaft of the 12T brushed motor.
It is slightly smaller than the 91THere are some clearer pictures. Do you have any clue the pitch for this gear? I am hoping it is 32P and is just a BLX part then I can find a 32P pinion that fits on the 3mm shaft of the 12T brushed motor.
