Outcast Outcast 4S broken part
Alex_d
Hello, I'm new to the hobby. I broke a piece(heard it was expected). I have no idea, though, of what I have to buy from the factory. Can someone please diagnose exactly? The picture is included. I hope it's the right forum. Thanks, everyone and Merry Christmas
Exploded view: https://www.arrma-rc.com/en/interactive-exploded-view?pid=ARA4410V2T3
Looks like you need a chassis & shock tower at minimum:
Chassis: ARA320798 (I'm assuming the new V2.5 chassis is compatible with the V2)
Shock Tower: ARA320633
You should go through it and check for more damage......very likely more things are broken. (Servo, steering bellcrank, links.....)
Looks like you lawn darted it or went head on collision into something hard. Nice work!
Merry Christmas!
Ho Ho ho!
Merry Christmas!
Looks like you Enjoyed yourself and Bashed it real good! 💥👊🤣👍
It's just the chassis and front shocks tower..
Yes we wanted to try it full speed but it occurred the car park was too small, so we bashed in concrete at roughly 50 Km/h. Lesson learned.
Thanks for your quick answer. I will carefully inspect if nothing else is broken because it was a very violent crash.
Cheers
Cheers
Those curbs are like mail boxes and trees they just jump right out in front of you 🤣
Yes next time I will go in a 300 meters prairie without trees or anything 😅😂 they are ridiculously powerful but it's part of the fun.
Those open fields can be a riot!
You'll be able to Bash even Faster / Harder!!
Chevy Truck Racing GIF by Dirt King Fabrication
How do I know exactly what part I need? For example, several chassis "look like" what I need. If I understand correctly, I have the Outcast 4s BLX. So I went on the page of the model https://www.arrma-rc.com/en/product/1-10-outcast-4x4-4s-v2-blx-stunt-truck-rtr/ARA4410V2.html
and went into the section "parts", https://www.arrma-rc.com/en/search?q="ARA4410V2Standardparts"&relationType=Standardparts&parentProduct=ARA4410V2
But for example, there are 2 chassis, does it mean any of the two would work?
Thanks a lot
One is the older design chassis the other is the newer design. You want the new V2 chassis https://www.arrma-rc.com/en/product/composite-chassis-mwb-v2-1pc/ARA320798.html
Thanks a lot
The 3S and 4S chassis are basically the same and interchangeable, the only difference is their lengths..
SWB = Short Wheel Base (Granites, Vorteks)
MWB = Medium Wheel Base (this is the stock length for your Outcast)
LWB = Long Wheel Base (Senton, Big Rock 3S, infraction 3S, Vendetta)
XLWB= Extra Long Wheel Base (in the Kraton 4S v2 & new v2.5)
XXLWB = Extra Extended Long Wheel Base (in the new Mojave 4S)
So with the longer chassis,the only thing you need is the appropriate length Center Driveshaft to match.
However, if in a pinch you "could" either Stretch the spring in the short driveshaft to make it work in the MWB chassis
or
Trim down the long Driveshaft from a LWB unit to fit..
Or even mix & match the different Driveshaft sections to make it work for whatever chassis you can get your hands on. 👊😉
Thanks a lot
If you have an owner's manual it should tell you the part number you need.
Hello,
"ADD TO CART" button doesn't work. I tried with Chrome, Brave, Firefox, and deactivating plugin and all.
Actually the cart itself is greyed out. Is it common? I remember already having got such issues to order the car.
Hello,
From which website?
