- 4x4-Mega
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Mojave
- Nero
- Notorious
- Talion
- Typhon 6s
My truck cam stock with the 17t pinion, has this happened to anyone else?
It came in at 33 mph running the 2S 40c.Sounds good, ill go ahead and order it. What kind of performance gains did the 26 give you?
Do have a p/n or link to the 27tooth pinion you got? Just installed a brushelees and still want more speed!That's fast! I've ordered a 27t pinion and a 3s lipo. Hope it holds up and I can get tthe same results
Can someone guve me a link to the 27tooth pinion gear? Does Arrma even sell the part? Thanks in advance.
Thanks, I guess I should've also noted I need it to be 48DP. I believe my motor has a 5mm shaft.
