Great i just ordered a 20T but then will probably getva 24T then sometimE, cause it would be awesome to have it running 60+.do you have any idea of how fast yours is goin?you shouldn't have any problem with that pinion change ivr ran a 24/50 on my stock motor with no heat problems at all.
Asphalt only? I can't see that being possible for anything else.you shouldn't have any problem with that pinion change ivr ran a 24/50 on my stock motor with no heat problems at all.
it actualy pretty fun bashing with it in the grass and on dirt large rooster tail and makes jumps fun in a park don't need a lot of space to get nice air. parks with people no problems getting nice airAsphalt only? I can't see that being possible for anything else.
take the four bolt that hold the esc tray out and it makes it easy to change pinion gear. it give you space to turn the l wrench to adjust the motorSo do i have to remove the engine to replace the pinion? Seems to be loctited. Or is there any easy trick to replace it?
