Printing TPU FAIL!
ArrmaK8
Hello!
Ive recently got TPU but when I tried printing something, the first layers were good but at the end (top) it messes up, look at the picture.
OVERTURE TPU
Flow: 110%
Nozzle temp: 210
Bed temp: 50
Fan speed: 0%
Get your flow down. If you print something solid with higher than 100% it's a guarantee to mess up. Material has no place to go to.
Fan speed to 20%, 40%+ on a small part like that.
What is your speed?
Fan speed to 20%.
What is your speed?
Ive tried 60, and then 40. No sucess...
Flow down to 100%. Try again. And turn on the fan so the layers are hard when the next one comes on top. Effect and cause here are correlating. As always when printing.
There is a learning curve to it. That's normal.
Ill try 100% flow, and 20% fan speed and then experiment with the settings.
Check your Retraction Distance
For Directdrive it should be around 2mm
or Less
I use the orginal Dremel software and it was set as that. But when I change the speed it also changes the retraction speed. But what does it mean?
Crank it down a bit more to 35mm/s for print speed.
Ohhh you meant retraction distance, i read it wrong.
or Less
It was 3mm before. Ill print it again, see you in 6 min
40% fan
2mm retraction distance
35mm/s
210C
50C
