Ive tried 60, and then 40. No sucess...Get your flow down. If you print something solid with higher than 100% it's a guarantee to mess up. Material has no place to go to.
Fan speed to 20%.
What is your speed?
Ill try 100% flow, and 20% fan speed and then experiment with the settings.Flow down to 100%. Try again. And turn on the fan so the layers are hard when the next one comes on top. Effect and cause here are correlating. As always when printing.
There is a learning curve to it. That's normal.
Direct drive, Dremel 3D45Is it a Bowden or Direct Drive?
Speed 40mm/s, and retraction speed is 65 or 70. Idk.What's your Retraction Distance and Speeds at?
I use the orginal Dremel software and it was set as that. But when I change the speed it also changes the retraction speed. But what does it mean?Check your Retraction Distance
For Directdrive it should be around 2mm
or Less
Ohhh you meant retraction distance, i read it wrong.Crank it down a bit more to 35mm/s for print speed.
It was 3mm before. Ill print it again, see you in 6 minCheck your Retraction Distance
or Less
40% fanOhhh you meant retraction distance, i read it wrong.
If it works, i wont touch it.I print TPU with 100% fan speed.
