Has to be the scorched mount thenPlenty of people run that motor in the limitless V2. It normally fits fine.
It definitely was in my case. It was hard to measure after it was installed, but the Scorched mount moved the motor out from the mount farther than the PPS mount by about 2-3mm. That’s a tiny amount, but it was the difference between fitting or shaving the bellcrank mount. This was for a sensored TP 5670 in a flipped mount on an SWB chassis.
look at the posts above yoursOk so I switched out the Scorched brace for the PP one and put the brace mount back up front. Using the PP brace pushed the front out ever so slightly that I now have about a papers width worth of room between the bell crank and the motor up until the bottom and then its tighter again. Not really sure what else it could be other than maybe the motor mount holes on the Scorched chassis are accidentally closer than they should be.
That’s great! I for one purchase a lot of scorched parts and is back n forth with David almost constantly. He is great at keeping in touch.I just checked it, it's snug all the way around. I think that rubber piece by the connections is throwing off the picture, it's kinda bowing to make it look not uniform.
Thank you! I've emailed David at Scorched and he's asked for more pictures, he's been great with any problems I've had. Scorched makes great products so don't let this one thing turn you away. There may be a simple fix and I'm just not seeing it.
