Problems with throttle
Kljin
  1. Infraction
  2. Notorious
Problems with my infraction 6S:
*reverse works in all modes 50/75/100
*throttle only works with 50 and NOT with 75/100
How do I get the throttle back working on 75/100?
Problems started after a couples drives with the BT2000 module installed.
Disconnected the module but the problem remains.
Does anyone know what the problem might be?
Help is much appreciated.
Assuming you are running the stock electronics, have you tried recalibrating the throttle?
I never liked or used the Throttle Limiter switch function with that radio. I even found my Braking changed drastically for the worse when I changed the power %.
Get a real radio. The Infraction needs a nice Long Range radio anyway. Like a RC4GS Radiolink. Only $60.00. A Gyro RX included. A Full featured multi-Model Radio. Additional Rx's are cheap enough as well. For adding new models as you advance. A win win. RTR radios are not all that. Once they get too finicky to deal with, its time to upgrade and don't look back. I always left my Thr Lim. on 100%. Less issues. Yet many use it as a crutch. A real RC radio doesn't use that Marketting Fluff. "Smart" features the same. Just more fluff. With no real benefit.
Same with the HB, yank it out and Toss it.
Problem seems to be solved for now.
Reinstalled the app on my phone and here is when i made the mistake.
When setting up the app, you have to choose from 'to transmitter' or 'from transmitter'.
Now i chose 'to transmitter' and that seems to have solved it.
Thanks for your responses.
