The lead comes with it.. well at least it did with the one I bought..hi, im going to get the above program card and guessing it wont come with the cable/lead. looking at the above picture is that a male to male
cable i need ? thanks for any replies.
thanks for that,its just all the pictures Ive seen of it on ebay etc don't show a leadThe lead comes with it.. well at least it did with the one I bought..
I wonder if there's a way to flash the full Hobbywing firmware onto the BLX185 - it's supposed to be the same hardware right?
Yep, I did the same:By looking at the chart in an owners manual. You can tell from the options which one you are changing. I made a little cheat sheet and taped it on the back to help remember.
TT
I knew a guy that did some software development and said it was pretty easy to get in the HW esc's programming.I think this has been discussed and concluded that it isn't possible. Sure wish it were though.
From what I recall of the discussion, the blx variation esc has some "lock" that doesn't allow deeper customization in the same way standard / branded HW esc does.I knew a guy that did some software development and said it was pretty easy to get in the HW esc's programming.
He indicated he figured out a way to remove the amperage limiting on the Max6 and Max5.
Sadly he lost his fight with cancer last year and took those secrets to the grave.
Soooo maybe others could figure it out. The only programming language I know is SQL and very little C
-Liberty
That’s just a hacking challenge.From what I recall of the discussion, the blx variation esc has some "lock" that doesn't allow deeper customization in the same way standard / branded HW esc does.
Could be but if I were Hobbywing, I might try to stifle a RTR (lower cost) esc in hopes to sell upgrades that would be attractive to hobbyists that wish to be able to tweak more.That’s just a hacking challenge.
All you need is the firmware file. Or a TFTP connectionIf onlyyyy they were programmable via computer so you could mess with the files straight through thereeee. Hobbywing should come out with a link feature. Even some hobbystars can be programmed through computer.
I'd love if it were that easy. Seems like many have tried though and should be able to find details and fixes posted at GitHub etc if it worked. These blx escs certainly aren't new. Hell, I'd even pay a bit to have the fix.All you need is the firmware file. Or a TFTP connection
