Yeah, just need to glue some cheap china eBay tires so it doesn't really matter about the fit and finish haha, will definitely try to find the tip applicator for when I get better tires, hopefully the $1 super glue works out, thanks manCyanoacrylate (CA) glue is synonymous with super glue. The only differences between all super-glues and CA glues is the thickness and dry time - both of which are controlled by additives. Hobby CA glue typically dries to tack in 1-3 minutes and comes with a fine tip applicator which is very helpful for precise placement of glue on the tire. You don't want the glue getting into the foam (some foams melt from glue) nor do you want a messy thick glue bead.
If you can get super-glue with a tip applicator, it's just as good as any "CA glue" sold for hobbies.
