ArrmAh
Anyone notice how the ends of the rear drive shaft rubs against the A-arms? I took apart the car to replace bearings and noticed how scuffed up the ends of the rear drive shafts were. I figured it was caused from the terrain I drove on before but after I put on the new drive shafts (I stripped the screw taking out the wheel axle) and turned the shafts to test, there was some resistance. The higher part of the shafts were touching the a arms.
Picture shows the old drive shaft with damage and new drive shafts on, circling where it rubs when it spins.
I'm guessing I could play with the camber to push it further away from the a arm where its touching..but there isn't that much play. A degree at most and i definitely don't want to have it over adjusted. Camber setting is stock btw.
