Vorteks Rear end won't move
My 2 front tires will move but not my rear end tires. What's wrong. It was working then boom it doesn't
The rear diff's ring gear probably exploded/Lost a couple of tooths or got ground down to knubs...
Yes. I lost e teeth on my pinion gear so I changed the pinion gear and then that's when it started happening
I lost 3 teeth I changed the pinion gear then that's when it started happening.
Will need pics and video to help you better diagnose your problem(s).
Can't go any further ,at this point.
