Vayneslashery
- Thread starter
- #21
Yeah that kinda where I was at, not caring about the wobble anymore but one of the wheels had started to wobble so bad that you can see the truck shift around in weird ways while going slow. Just can't ignore that anymoreOn several of my big rock axles from factory I had a similar wobbly issue. I finally pulled the driveshaft because one of the wheels kept falling off no matter what I did. On all three there was factory Loctite in the bottom, so much that the screw wasn’t allowed to seat all the way in.
I found I could tell by looking at my driveshafts when I pulled them from the vehicle. The axel is supposed to be all the way in with just a little bit of the slotted part visible. On mine half the slotted part was exposed. I cleaned out the axles with a small drillbit then soaked in brake cleaner to get the rest out. Then I didn’t have any more issues.
Occasionally I will bend an axle jumping or just beating on the car. It’s not a big deal though and I really don’t worry about it. As long as the axle is secure I don’t care if it wobbles a bit anymore.
