bme107
- Points
- 73
- 4x4-Mega
- Granite
- Senton 6s
We have a Senton Mega, a Granite Mega and a Granite 3s. All 2018-2019 era. Last used in early 2021 and running fine when they were shelved, fully disconnnected from power. Batteries removed from controlers too. I charged them up this week and decided to give them a run.
All 3 of them turned on fine but the steering servos seems to be convulsing on all of them.
1. Ganite Mega runs forward and back but has no steering. Every few twists of the wheel and it partially turns then becomes unresponsive again. Holding it up off the ground the servo seems to be jittering back and forth.
2. Granite 3s exact same thing.
3. Senton started out with the exact same issues as both of the other trucks. After a good 2 minutes of slowly driving back and forth in the basement rowing the controler steering back and forth it seems to have "freed up". It now steers fine but when you pick it up the servo jitters back and forth on it's own.
Any ideas as to what is going on? Is there some sort reset procedure that I could do. Is something not pared between the controllers and the receivers? If it was just one truck I'd chaulk it up to a bad steering servo, but all 3? And one truck partially improves with use......I'm at a loss.
