- Infraction
- Kraton 6s
- Mojave EXB
- Senton 3s
Whatās up yāall, kind of already started this build prior to making this account but will post whatās done so far and update as I go
Grabbed a Senton V3 Blx after having 2 K6s wanted a 10th scale.
Started off with motor bearing issues after my 2nd/3rd use, replaced bearings twice in the spektrum 3200 than a shaft problem.. warrantied thru HH but was back ordered for about a month or so. I was not aware of Jennyās at the time so my lhs recommend me a castle mambaX/4600kv motor.. terrible combo motor got extremely hot after a few runs fan setup seemed pointless to me but was told it was still helping lol.
Moving forward added a dusty motors cover to keep all the debri that gets In the chassis. Along with some blue ābig boreā shocks. (Broke the shaft on the stock arrma shocks)
Next was another motor lol went castle again but 3800kv with 5mm shaft. Seen that was the one they paired with there race series/sct application. Have had good luck so far did have to do bearings and it was getting hot again on 3s, I use the truck what itās intended for flat surface racing on dirt/gravel/sand. KV drop helped but would still get hot on 3s even with 15t pinion.. cut off on me once with temp set to 140ish.
Soooooooooo finally today we have a new package!
Thing of beauty I tell ya , going to slap this 2400kv in with a 18t piƱon(better suggestions please let me know) add a double fan thatās coming today and Iām expecting zeroooo heat issues on 3s I may even grab a 4s pack just to give it a shot.
I donāt have much planned for it after this besides maybe some metal gears down the line/diff yokes. Since finding out about Jennyās Iāve ordered a host of spare parts to have Incase breakage.
-Hubs/bearings
-Driveshafts
-Diff with bearings/new gears
-13t input gear(2)
-Steel Turn buckles
-stock servo
-Rpm A arms F/R
-Fast eddy bearings for car/motors
-Tire glue
-Shock oil
-Diff fluid
-spur gears(3)
-slipper pads
-body clips
Will update once motor goes in and I give it a run!
-Hubs/bearings
-Driveshafts
-13t input gear(2)
-Steel Turn buckles
-stock servo
-Rpm A arms F/R
-Tire glue
-Shock oil
-Diff fluid
-spur gears(3)
-slipper pads
-body clips
