Servo replacement!!
Pepaw18
Middletown,Ohio
  1. Vorteks
I have a Vorteks and going to replace stock servo. What is a good but budget friendly servo. I have seen and heard about the ones on Amazon. Some are 20kg and 25kg. Will these work on my Vorteks.
It says the stock servo is 23 and these on Amazon say the require 25. So that way I'll get and see.
This is what I put on mine a while back and have had no issues... You will need the servo saver in picture to fit 25 tooth servo
On jennysrc.com you can get the s652 servo from the 6s line for 16 bucks. It’s great in the 3s line, drops right in and is 23t. Also pick up a couple or more steering assemblies, includes the bellcrank, bearings, link and servo saver for less the 3 bucks. Here’s the links.
https://jennysrc.com/collections/ar...um-s652-digital-steering-waterproof-ara8608v5
https://jennysrc.com/collections/ar...g-bellcrank-servo-saver-post-senton-ara4305v3
I haven't broke the arrma 25 tooth one yet and have crash jumped and bashed alot, managed to break a lot of stuff around it but that's held up pretty good lol
Has your 25t softened up over time? I’ve never tried one out. I haven’t ever had a 23t Arrma saver break. They just get weak, the plastic bell crank and link also get weak and bearings crunchy. Which is why I swap them out when steering begins to suffer.
