Pepaw18
I have a Vorteks and going to replace stock servo. What is a good but budget friendly servo. I have seen and heard about the ones on Amazon. Some are 20kg and 25kg. Will these work on my Vorteks.
Look in your manual.. at the parts diagram and see what the number is!Are you sure mine is a 23 servo savo. Thought they needed a 25tooth saver
This is what I put on mine a while back and have had no issues... You will need the servo saver in picture to fit 25 tooth servoIt says the stock servo is 23 and these on Amazon say the require 25. So that way I'll get and see.
On jennysrc.com you can get the s652 servo from the 6s line for 16 bucks. It’s great in the 3s line, drops right in and is 23t. Also pick up a couple or more steering assemblies, includes the bellcrank, bearings, link and servo saver for less the 3 bucks. Here’s the links.I have a Vorteks and going to replace stock servo. What is a good but budget friendly servo. I have seen and heard about the ones on Amazon. Some are 20kg and 25kg. Will these work on my Vorteks.
Ugh, I tried that one and it lasted 4 runs and the spring broke. Not worth it for the priceNow it's getting interesting, get the HR saver!!
Mine work flawlessly!!Ugh, I tried that one and it lasted 4 runs and the spring broke. Not worth it for the price
You got one of the few good ones then.Mine work flawlessly!!
I haven't broke the arrma 25 tooth one yet and have crash jumped and bashed alot, managed to break a lot of stuff around it but that's held up pretty good lolMine work flawlessly!!
Has your 25t softened up over time? I’ve never tried one out. I haven’t ever had a 23t Arrma saver break. They just get weak, the plastic bell crank and link also get weak and bearings crunchy. Which is why I swap them out when steering begins to suffer.I haven't broke the arrma 25 tooth one yet and have crash jumped and bashed alot, managed to break a lot of stuff around it but that's held up pretty good lol
I run 2 of them with a 3rd in the near future!!You got one of the few good ones then.
Senton, 3s infraction and what else? Wait, you have more than one senton right?I run 2 of them with a 3rd in the near future!!
