PittsburghJason
- Outcast 4s
Posted this on fb not long ago and figured I would share here.
Did some research and fixed the servo saver once and for all. No box cutting either, just cut the tip of the servo saver and space the servo with 10mm spacers. It's that simple with the right parts.
The treal servo saver works well and can be adjusted from weak stock steering all the way to too stiff that it will break your servo. Spaced it with 9mm hot racing m3 standoff spacers and 1mm m3 washers, plus a standoff spacer for the power button. Working so well that I threw a bunch of camber and toe out on my front wheels so it doesn't roll over. Now it corners fast on any surface.
Treal Aluminum 7075 Servo Saver Set 25T for LMT Monster
https://www.amazon.com/dp/B091YBRD1Z?ref=ppx_yo2ov_dt_b_product_details&th=1Hot Racing SPC3007 M3 Aluminum Standoff Spacer Set (4x)(3-5-7-9mm)
https://www.amazon.com/dp/B00XF8HFQ6?psc=1&ref=ppx_yo2ov_dt_b_product_detailsM3 1mm washers and longer m3 screws are also needed.
