Tekno Orange springs with heavier wt oil is popular.
did you need to change the shock mounts? what did you have to do to retrofit the tekno's?These will do the trick. I just got them, but have yet to put the together. I think the rear is 2 or 3 MM short of the stock. I am waiting on some Team Ass Green Slime. I got the 4 hole piston, though I am thinking I probably want a couple more holes.
http://www.teknorc.com/shop/tkr6153-full-option-shock-kit-137mm-no-springs-no-pistons/
http://www.teknorc.com/shop/tkr6152-full-option-shock-kit-122mm-no-springs-no-pistons/
Check out the Kraton Forum, we have this thread going one over there.
https://arrmaforum.com/threads/replacement-kraton-shocks.3072/
Here are the rear shocks mounted on a kraton (not mine). Like @Vanning said, they might even be too nice to bash with em.
You will need to order the Tekno Standoffs and the Tekno Bushings. The standoff has an M4 size post, and the stock has an M3. So you have drill out the hole, on the shock tower just slightly. Also if you buy the full option shocks, you will also need to buy some pistons. You could take the pistons out of the stock shocks, but that’s twice the work. I like having back up parts and having a full set of ready to go back up shocks makes me all warm inside.
The shafts were still 4mm though right?
